There is no way to increase the backplane capacity of 6500 from 720 Gbps. If you require high density gigabit ethernet connectivity, then this is what the 256G Crossbar switch fabric is designed to support. The current capabilities of the 6500 is that it supports a 16 G bus architecture, so you could possibly over-subscribe the existing switch with more than one 16 port Gig module.
