X25 over ip in mpls vpn l3 environment
Oct 22nd, 2007
  • Bronze, 100 points or more
Good day all,
We have to migrate a router to PE but this router has one interface configure with x25 without ip address. Normally this router has to join another x25 router with x25/ip. How can we proceed to the configuration to bring x25 into the vrf ?
How to configure x25 over ip between PE-PE into Mpls vpn layer 3 ?
Any help 'll be really appreciated.
Best regards.
Stephane.
paolo bevilacqua Mon, 10/22/2007 - 06:36
  • Hall of Fame,
    Founding Member
mpls doesn't care about the traffic it carries.
So as long you can ping both routers, you XOT will be fine.
stephtchoko Tue, 10/23/2007 - 00:26
i agree with you about about the fact that the mpls don't care about the traffic it carries.
See the case below:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a008009486c.shtml
Suppose that R2 and R3 are PE, PE-PE are linked by mpls.x25 traffic goes througth vrf name TEST.
How can we perform this task ?
Best regards.
Stephane Tchoko.
paolo bevilacqua Tue, 10/23/2007 - 03:57
  • Hall of Fame,
    Founding Member
As I was saying before, as long each PE router can ping the other, XOT traffic will be OK.
As a recognition to those providing ansers, please rate all posts using the scrollbox below!
