Power consumption, in kVA?
Answered Question
Oct 22nd, 2007
Guys, I am building a data center and I need to find power for my network gear based on kVA and volts. So far I found power specification for my Cat 6509 and router 3845 in Watts.
Anyone here know how I can find kVA info for each of the devices I listed above. I've done a search on cisco.com, but that information is not clear to me.
Correct Answer by jerry.bonner about 9 years 9 months ago
news,
You're probably trying to figure out how big of a UPS you're going to need since those are typically sized in kVA.
kVA is more or less equal to a kilowatt, assuming that all your power supplies are power factor corrected, which nearly all modern ones are.
So if your drawing 15amps at 120volts, you're pulling 1800 watts or 1.8 kVA ( watts = volts * amps and theres 1000 watts in a kilowatt / kilovolt-amp etc).
Hope that helps
Overall Rating: 5 (1 ratings)
Correct Answer
jerry.bonner Mon, 10/22/2007 - 14:38
news,
Hope that helps
