10-22-2007 10:27 AM - edited 07-03-2021 02:48 PM
i have config a CISCO 876W to use WEP128. I have Access over WLAN, but clients dont get a dynamic IP from this Router over WLAN. The Router works fine over Ethernet . If i deactivate WEP128, then i get a IP over this WLAN.
my IOS:
c870-advipservicesk9-mz.124-15.T1.bin
my config:
version 12.4
no service pad
hostname MENDOZA
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xxxxxxxxxxxxxxxxxxxx
no aaa new-model
dot11 ssid CISCO
authentication open
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool1
import all
network 10.10.10.0 255.255.255.0
dns-server 217.xxx.xxx.xxx 192.168.3.150
default-router 10.10.10.1
ip domain name WORLD.net
ip name-server 217.xxx.xxx.xxx
ip name-server 192.168.3.150
username xxxxxxxxxx privilege 15 secret 5 xxxxxxxxxxxxxxxx
archive
log config
hidekeys
bridge irb
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
no snmp trap link-status
pvc 1/32
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
encryption key 1 size 128bit 0 11111111111111111111111111 transmit-key
encryption mode wep mandatory
ssid CISCO
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxxx
interface BVI1
description $ES_LAN$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1412
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
webvpn cef
end
MENDOZA#
10-26-2007 11:05 AM
I am sure the following ISR authentication configuration document should help you.
