which way?
Oct 22nd, 2007
Can someone tell me which way "packets input" and which way "packets output" is if you have a server connected to the port?
Overall Rating: 4 (1 ratings)
Richard Burts Mon, 10/22/2007 - 12:20
Is the context of this question access lists and input or output? If so then in and out are always from the perspective of the router or switch that is processing the list. From the server into the router/switch is "in" and from the router/switch out to the server is "out".
If the context of the question is something else then please clarify what the question is about.
