C3750G-24TS and SSH
Oct 22nd, 2007
I have a C3750G-24TS Ver 12.2(25)SEE1
I am trying to connect with putty and am getting error "Connection refused". I have set a username and password.
used Line vty 0 15
login local
Telnet in no problem but want to disable and just use SSH.
glen.grant Mon, 10/22/2007 - 13:43
Have you configured the rest of the parameters on the 3750 to support SSH? Does the code installed on the 3750 even support SSH ???
servnj Tue, 10/23/2007 - 10:14
You are right, I entered crypto ? and it comes back unrecognized command. The image I have now is
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(25)SEE1, RELEASE SOFTWARE (fc1). I will look for IOS that supports SSH.
szahid Tue, 10/23/2007 - 10:24
The image that you will need to support crypto has to have a "k9" in the image name. For example , an equivalent image to the one you have + crypto suppot will be c3750-ipbasek9-mz.122-25.SEE1.bin.
