RSPAN, SPAN and general monitoring techniques
Answered Question
Oct 22nd, 2007
I have a dilemma. I need to monitor 4 links. for inbound and outbound traffic. A hub is out of the question as traffic won't be seperated. Currently I am using a product called nTap to tap the four links back to a Cisco switch. The problem is SPAN only allows for 2 sessions. So 2 links can't be monitored. Attached is a diagram. Would RSPAN be better? Is RSPAN easier to configure? What exactly is VSPAN and when would it be best applicable?
Correct Answer by Kevin Dorrell about 9 years 9 months ago
So, create an RSPAN VLAN and make sure it goes wherever you need it.
Then, on the switch(es) you want to source from:
monitor session 1 source interface f2/2 options
monitor session 1 source interface f2/8 options
etc
monitor session 1 destination remote vlan 40
exit
show monitor
On your sniffing switch
monitor session 1 source remote vlan 40
monitor session 1 destination interface f0/4
exit
show monitor
Kevin Dorrell
Luxembourg
Overall Rating: 5 (1 ratings)
Kevin Dorrell Tue, 10/23/2007 - 07:15
  • Green, 3000 points or more
I am sure this will be possible.
Generally, it is not one session per port source monitored. Each session can monitor several ports in the switch.
But before I give you a load of configs that you cannot use, what sort of switches are you working with: IOS or CatOS. And what model?
Kevin Dorrell
Luxembourg
brandon.n Tue, 10/23/2007 - 07:28
Thanks Kevin... we have any switch you can name. Preferably I want to do it on a 3550 but a 3750 is okay as well. IOS version only, no CatOS.
Correct Answer
Kevin Dorrell Tue, 10/23/2007 - 07:53
etc
exit
show monitor
exit
show monitor
Kevin Dorrell
Luxembourg
brandon.n Tue, 10/23/2007 - 08:18
Excellent Kevin.. I will try this. Your help is greatly appreciated :)
Konstantin Dunaev Tue, 10/23/2007 - 23:31
  • Bronze, 100 points or more
don't forget that on low-end switches eg. 2950, 2970 you need the mirror port to configure the RSPAN session. that ports should no be used and should not be in "disable" status.
