Port Translation in PIX 7.2
Oct 22nd, 2007
I have a server with an applications running in the port 9080 behind a PIX, some users from Internet that are using other firewalls are not able to reach the port 9080 due restrictions. I want to know if my PIX firewall is able to translate a 80 port lookup to 9080 that is served by the server?
Overall Rating: 4 (1 ratings)
Patrick Iseli Mon, 10/22/2007 - 20:22
Yes this is possible.
For Port address translation you can use :
1.) SRC Port 9080 to DST port 9080
2.) Or you can also use the SRC Port 80 to DST Port 9080
Example of option 2:
access-list acl_outside permit tcp any host PublicIP eq http
access-group acl_outside in interface outside
static (inside,outside) tcp PublicIP http IntenalIP 9080 netmask
Replace the PublicIP and the InternalIP by the RealIP Address.
