ASA5505 Programming - issue with outside
Oct 22nd, 2007
Hi Gurus,
I'm having a HELL of a time getting a new ASA 5505 online.
in the test environment I can ping my internal gateway, but I can't ping the external IP or the external next-hop gateway IP.
Not sure where I went wrong. Can someone clue me in? Run Config is attached.
caught this on a reload too:
..WARNING: static redireting all traffics at outside interface;
WARNING: all services terminating at outside interface are disabled.
*** Output from config line 105, "static (inside,outside) ..."
my outside IP is masked. Thanks.
sundar.palaniappan Mon, 10/22/2007 - 16:48
  • Green, 3000 points or more
I see a couple of things missing in your configuration. Can you make the necessary changes and try.
1. Access list entry to permit icmp echo replies on the outside interface.
"access-list outside_access_in extended permit icmp echo-reply"
2. A default route on the PIX to forward all traffic to the external gateway on the outside.
"route outside 0.0.0.0 0.0.0.0 "
Sundar
