Clientless SSL VPN Questions
Oct 22nd, 2007
When using a Clientless SSL VPN, is it possible to have the MAC address of the remote client pass through to an internal application? We are using a specific app that queries the connecting computer for it's MAC address before it will set up a session. The application runs fine when I connect the remote client via a full SSL VPN tunnel, but I'd prefer to go clientless SSL VPN with a published application link using Smart tunnels.
vkapoor5 Fri, 10/26/2007 - 13:20
  • Bronze, 100 points or more
Clientless SSL VPN (WebVPN) allows a user to securely access resources on the corporate LAN from anywhere with an SSL-enabled Web browser. The user first authenticates with a WebVPN gateway which then allows the user access to pre-configured network resources. WebVPN gateways can be configured on Cisco IOS routers, Cisco Adaptive Security Appliances (ASA), Cisco VPN 3000 Concentrators, and the Cisco WebVPN Services Module for the Catalyst 6500 and 7600 Routers.
http://www.cisco.com/en/US/products/ps6496/products_configuration_example09186a008071c58b.shtml
