Event Viewer - Cisco TFTP
Oct 22nd, 2007
Hi all,
Just recently, our Publisher is generating errors under Event Viewer on Cisco TFTP. Message is below:
User: N/A
Computer: CallManager Publisher
Source: Cisco TFTP
Event ID: 1
The description for Event ID (1) in Source (Cisco TFTP) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: ChangeNotify-CRecieveThread::BlockWorker(absent without leave)
The description for Event ID (1) in Source (Cisco TFTP) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: ChangeNotify-CRecieveThread::BlockPartWorker(bind fail(10048))
The error is generated every 1min.
The server has has been operational since mid this year and the error started recently.
Any advise?
bwilmoth Fri, 10/26/2007 - 13:40
To resolve this problem, perform this procedure:
If any antivirus software is installed on the TFTP server, disable it.
If TFTP file caching is enabled, disable it.
To disable TFTP file caching, follow these steps:
Go to the Service/Service Parameter page, and select TFTP Service.
Click the Advanced button.
Enable the Caching of Constant and Bin Files at Startup parameter.
Set the Enable Caching of Configuration Files to false.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_bulletin0900aecd800f8572.html
metalium2007 Sat, 10/27/2007 - 01:43
im having the same problem.
The proposed doesnt work. There arent any SEP files generated.
Could this be a virus?
Any hint?
metalium2007 Sat, 10/27/2007 - 04:54
Same problem with:
CCM 4.2.3 SR1
OS 2000.4.4SR2
After upgrade to:
CCM 4.2.3 SR3
OS 2000.4.4.SR11
Problem solved.
Hope it helps.
Met.
Peter Valdes Sun, 10/28/2007 - 00:42
I will try both and see what happens. Thanks for the reply.
I'm currently running OS 2000.4.5 with 4.5aSR2 and also CallManager 4.2.1SR1b.
