Should this route be in the EIGRP topology table?
I have a network as follows:
mcb-core
t2/1 directly connected to t2/1 on hbg-core
g9/8 connected thru ethernet net to g7/5 on hbg-core
g9/33 directly connected to f0/1 on mcb-vpn
hbg-core
t2/1 directly connected to t2/1 on mcb-core
g7/5 connected thru ethernet net to g9/8 on mcb-core
mcb-vpn
f0/1 directly connected to g9/33 on mcb-core
mcb-vpn originates route (via static redist) to 10.214.210.0/24.
mcb-core#show ip eigrp top 10.214.210.0/24
IP-EIGRP (AS 1): Topology entry for 10.214.210.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 25856
Routing Descriptor Blocks:
10.214.206.3 (GigabitEthernet9/33), from 10.214.206.3, Send flag is 0x0
Composite metric is (25856/1), Route is External
Vector metric:
Minimum bandwidth is 100000 Kbit
Total delay is 10 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 1
External data:
Originating router is 10.214.206.130
AS number of route is 0
External protocol is Static, external metric is 0
Administrator tag is 0 (0x00000000)
10.214.208.66 (GigabitEthernet9/8), from 10.214.208.66, Send flag is 0x0
Composite metric is (256768/26112), Route is External
Vector metric:
Minimum bandwidth is 10000 Kbit
Total delay is 30 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 3
External data:
hbg-core#show ip eigrp top 10.214.210.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 26112
10.214.208.0 (TenGigabitEthernet2/1), from 10.214.208.0, Send flag is 0x0
Composite metric is (26112/25856), Route is External
Vector metric:
Total delay is 20 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 2
External data:
10.214.208.65 (GigabitEthernet7/5), from 10.214.208.65, Send flag is 0x0
Composite metric is (256512/25856), Route is External
Vector metric:
Load is 1/255
Minimum MTU is 1500
Hop count is 2
External data:
mcb-core obviously shows the successor as the path through mcb-vpn (g9/33). However, do I read this correctly in that the feasible successor is hbg-core through the ethernet link (g9/8)?
The reported distance for that link (26112) is higher than the feasible distance for that subnet (25856) as calculated by mcb-core. This is because that path would take traffic through the Ethernet net to hbg-core, then out the 10gig link back to mcb-core, then on to the mcb-vpn. What puzzles me is why that path is shown in the topology table since the reported distance is larger than the feasible distance, thus not matching the feasibility condition for EIGRP?
Thoughts? Am I interpreting things correctly?
Also note that the the mcb-core and hbg-core are 6509s, the mcb-vpn is a 2651. Oddly enough, show ip eigrp top on the 6509 does not give the distances. You have to do show ip eigrp top x.x.x.x/y to get this. I don't know why.
I may have figured it out, but am not sure.
"show ip eigrp top" simply lists
P 10.214.210.0/24, 1 successors, FD is 25856
via 10.214.206.3, GigabitEthernet9/33
Is it the case that show ip eigrp top x.x.x.x/y shows all items learned, even those which don't meat the feasibility condition and thus aren't feasible successors? Whereas the simple show ip eigrp top shows only successors and feasible successors?
Konstantin Dunaev Wed, 10/24/2007 - 00:33
"show ip eigrp top all" shows all links, even those which don't meet the feasibility condition.
"show ip eigrp top" should show only those which meet the feasibility condition.
