ASDM is asking for Authentication
Answered Question
Oct 22nd, 2007
I have upgrade my Pix515E from IOS 6.2 to 8.0, and ASDM to version 602
when I am accessing the ASDM through java site or through the client sw it's asking for Authentication
Authentication is required
please login to authenticate to pix_ip
I don't have any authentication seted on the pix.
any ideas ??
Correct Answer by pjhenriqs about 9 years 2 months ago
If you can telnet into the PIX, then just create a username with privilege level 15 and then try to use that to access the ASDM.
I think that solves your problem.
username X privilege 15 secret Y
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Mon, 10/22/2007 - 20:12
Ahmed, the asdm authentication is the same as before upgrade by using enable password to access fw.
if you have not setup enable password console to pix and set one up
e.g
pix(config)#enable password xxxxx
reagentom Mon, 10/22/2007 - 20:19
Hi jorge
I have enable password, but it's working like that
when run ASDM it will ask for password to pix then I will enter the enable password. it will accept it then another window will come asking please enter password for authentication.
pjhenriqs Tue, 10/23/2007 - 01:47
It should still be the enable password.
That has to do with the Java thingy and certificates that makes you put the same password twice.
Let me know if it helps.
pjhenriqs Tue, 10/23/2007 - 03:40
Can you share the config with us?
From the top of my head, if you have not configured any authentication on the PIX, then it should be something like username cisco and password cisco (or user pix and pass cisco).
JORGE RODRIGUEZ Tue, 10/23/2007 - 04:14
In adition to Paulo's comments, can you authenticate at all when you telnet to pix or console to it? if you can get in pix enable mode via console or telnet the enable password is there, so I would think it would have to do with Java as Paulo indicated, can you use another PC to https to pix, it would be odd that enable password would have changed in the upgrade process but worth give it a try as anything is possible.
reagentom Tue, 10/23/2007 - 04:22
No jorge, enable password is working fine through the consol and telnet, even through ASDM also it's accepting the enable password then after that it's asking for this magic authentication password !!
I will try it with another pc and let us see how is it.
reagentom Tue, 10/23/2007 - 04:16
PIX Version 8.0(2)
hostname PIX
domain-name Mecit.edu.om
names
name 10.2.2.3 ex1
name 192.168.101.0 ex323
name 10.2.0.0 ex2
name 192.168.101.4 exxx
name 192.168.101.3 xxxxx
name 192.168.101.5 xxxxx
name 192.168.101.10 xxxx
name 10.2.2.254 xxxxx
name 192.168.101.11 xxxxxx
dns-guard
interface Ethernet0
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.240
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.101.2 255.255.255.0
passwd xxx
boot system flash:/pix802.bin
ftp mode passive
dns server-group DefaultDNS
domain-name xxx.com
access-list inside_access_in extended permit ip Server_Network 255.255.0.0 any
access-list inside_access_in extended permit ip host xxxxx any
access-list outside_access_in extended permit tcp any host x.x.x.x
pager lines 24
logging enable
logging asdm-buffer-size 512
logging asdm warnings
mtu outside 1500
mtu inside 1500
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit attack action alarm drop
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image flash:/asdm-602.bin
asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) x.x.x.x
x.x.x.x netmask 255.255.255.255
static (inside,outside)x.x.x.x
x.com netmask 255.255.255.255
static (inside,outside) x.x.x.x XX
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 X.X.X.X
route inside XXXX 255.255.0.0 192.168.101.1 1
route inside ExchSVR 255.255.255.255 192.168.101.1 1
route inside AHMED 255.255.255.255 192.168.101.1 1
route inside XXX 255.255.255.255 192.168.111.1 1
route inside XX 255.255.255.255 192.168.101.1 1
route inside XXX 255.255.255.255 192.168.101.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http XXX 255.255.255.255 inside
http XXXX 255.255.255.255 inside
http Ahmed 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
no sysopt connection permit-vpn
no crypto isakmp nat-traversal
telnet 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
ssh version 1
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect http
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
tftp-server inside TFTP C:\TFTP-Root
prompt hostname context
Cryptochecksum:xxx
: end
Correct Answer
pjhenriqs Tue, 10/23/2007 - 05:05
