set up different bandwidth on LAN interfaces of router
Oct 22nd, 2007
i have set up a small lab for testing optimization of certain applications...i have connected two routers with gigabit port to be utilized as WAN connections..since gigabit port supports 1000mbps, but i want to have only 1Mbps or 2 Mbps i.e less than 1000Mbps between both routers...means i want to make LAN port as WAN port..
how to achieve this bandwidth...kindly provide the configuration to achieve this..
Overall Rating: 4 (1 ratings)
guruprasadr Mon, 10/22/2007 - 21:08
Gigabit capacity of "1000mbps" is just the speed of the interface.
This "1000mbps" is not related to the Bandwidth incoming / outgoing.
Do provide more details on the same.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
bvsnarayana03 Mon, 10/22/2007 - 21:24
u may change the bandwidth parameter on the interface by getting in to interface config mode & giving the command "bandwidth xyz" in kbps.
Pls note that the bandwidth command is used for metric calculations only, it doesnt change the interface performance.
Another alternative is, since u r plannig to simulate WAN on router interfaces. Simply vary the metric of interface to the respective routing protocol used, instead of varying BW.
royalblues Mon, 10/22/2007 - 23:06
If you want to restrict the fastethernet speed to say one or 2 mbps for your simulation, i would suggest you configure Policing or shaping
policy-map wan-restrict-out
class class-default
police CIR 200000 conform-action-transmit exceed-action -drop
interface fastether 0/1
service-policy output wan-restrict-out
configure this on both the sides and you should be good to go
