Unequal Paths ISIS
Oct 23rd, 2007
Hey Guys,
I have encounted a problem.
I have 5 = 1 Gbps Links going from a 7609 router to a C10008 (10K) router.
I enabled all the links with proper ip address configuration..and have 5 isis neighborship established..
But why is there only traffic being passed on 4 links?
The BGP maximum-paths is set to 5
The maximum-paths command is set to 2
What is the solution to this riddle??
Harold Ritter Tue, 10/23/2007 - 04:48
The default maximum-path for isis is 4. Try settinh it to 5 (or greater).
Mavrick25 Tue, 10/23/2007 - 06:32
Hritter - CCIE
Thank you very much..
It worked, thank you very much
Mav
