ACS - list the configuration
Answered Question
Oct 23rd, 2007
How can I list the configuration applied to all users and group on ACS (in just one file)? There are around 300 users.
Basically I need the information about maximum sessions by each user (can be on .txt or .csv file).
I think this information is available on the files generated by the backup. But I don't know if it is readable.
Marcelo
Correct Answer by Premdeep Banga about 9 years 9 months ago
As such there is no tool on ACS with which you can get such report/information.
But you can contact Extraxi (www.extraxi.com) and check if they can help you with, what you are trying to achieve.
Overall Rating: 5 (2 ratings)
Correct Answer
Premdeep Banga Wed, 10/24/2007 - 08:18
  • Gold, 750 points or more
