VPN L2TP Error - QM FSM - ASA 5505 v8
Oct 23rd, 2007
I have a problem when i want to create a LTP/IPSec VPN between my PC and an ASA 5505. There is Already a LAN2LAN VPN IPSec configured on the ASA.
Here the logs:
Group = DefaultRAGroup, IP = 90.10.117.178, PHASE 1 COMPLETED
Group = DefaultRAGroup, IP = 90.10.117.178, QM FSM error (P2 struct &0xd54895a0, mess id 0xf0b712)!
Group = DefaultRAGroup, IP = 90.10.117.178, Removing peer from correlator table failed, no match!
I follow the VPN remote access Wizard.
mattiaseriksson Tue, 10/23/2007 - 02:46
  • Bronze, 100 points or more
Hi, can you post the configuration from the ASA?
