pjhenriqs Tue, 10/23/2007 - 01:54
The show version command gives you the serial number. It should also give you the modules.
Hope it helps.
massimiliano.se... Tue, 10/23/2007 - 02:08
  • Silver, 250 points or more
I've tried before your reply, but i obtain only one serial number, and not the serial numbers of the installed modules.
Thank you.
Best regards.
Massimiliano
pjhenriqs Tue, 10/23/2007 - 02:16
What version do you have? PIX or ASA?
I would guess that looking through a "show tech-support" should show what you want. Not sure though.
Paulo
massimiliano.se... Tue, 10/23/2007 - 02:19
It's a PIX.
Not showed the serial numbers with "show tech-support".
Best regards.
Massimiliano.
