IPSEC VPN with PAT for the interesting traffic
Oct 23rd, 2007
R1--PIX1 -----Ineternet----PIX2-----R2
Lo0R1-->1.1.1.1
PIX1(inside) -->10.1.1.10
PIX1(Outside) -->219.x.x.55
Lo0R2 -->2.2.2.2
PIX2(inside) -->20.1.1.10
PIX2(Outside) -->139.x.x.65
I need to configure IPSEC VPN between PIX1 ,PIX2 and the interesting traffic is between LO0R1,LO0R2 .
The problem is that the PIX2 allows the 219.25.4.55 only So i don't know how can i confgure that ?
Do i need to PAT the lo0R1 to 219.x.x.55 ? Do i need Nat-Traversal?
PIX1
interface Ethernet0
nameif outside
security-level 0
ip address 10.1.1.10 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 219.x.x.55 255.255.255.0
access-list encrypt extended permit ip 1.1.1.0 255.255.255.0 2.2.2.0 255.255.255.0
access-list nonat extended permit ip 1.1.1.0 255.255.255.0 2.2.2.0 255.255.255.0
nat (inside) 0 access-list nonat
static (inside,outside) 1.1.1.1 219.25.4.55 netmask 255.255.255.255
crypto ipsec transform-set tset esp-3des esp-md5-hmac
crypto map myvpn 10 match address encrypt
crypto map myvpn 10 set peer 139.25.14.65
crypto map myvpn 10 set transform-set tset
crypto map myvpn interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal 20
tunnel-group 139.25.14.65 type ipsec-l2l
tunnel-group 139.25.14.65 ipsec-attributes
pre-shared-key *
Overall Rating: 5 (1 ratings)
krishnakomiti Tue, 10/23/2007 - 03:06
Please configure the below steps for VPN:
PIX---1
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map myvpn 20 ipsec-isakmp
crypto map myvpn 20 match address encrypt
crypto map myvpn 20 set peer 139.25.14.65
crypto map myvpn 20 set transform-set test
isakmp key ******** address 139.25.14.65 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 1000
Thanks ,
Krishna.
welcomeccie Tue, 10/23/2007 - 03:56
thanks Krishna for your reply but PIX2 permit only 219.25.4.55 so i should nat the interesting traffic to that ip and i can't use nat 0
sorghum_gao Thu, 10/25/2007 - 09:19
You can use easy vpn client mode to solve the problem.
