1Gig throughput problem
Oct 23rd, 2007
I'm running a throughput test between a 6500 and a 3750E with a SX MM connection, 50 meters.
Using an app that pumps out 5k udp discard packets in one direction my out put interface looks like this:
30 second output rate 997298000 bits/sec, 92385 packets/sec
Queueing strategy: fifo
Output queue: 0/40 (size/max)
While on the other end I see:
30 second input rate 945345000 bits/sec, 87971 packets/sec
Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 0
Where is my 50mbits? Im guessing its getting lost in the fibre and the joins of the patch leads?
cpu is ok.
ta
krishnakomiti Tue, 10/23/2007 - 03:23
Please recheck the Speed and Duplex on both end switches.
Krishna.
Kevin Dorrell Tue, 10/23/2007 - 05:50
Could you please post a full show int int and a show int int counters detail from each side? I think the reason will become evident from those diagnostics.
Kevin Dorrell
Luxembourg
