ACS 4.1 Remote Change Password Issues.
Answered Question
Oct 23rd, 2007
I need some help with getting Remote change password working. The user gets challenged to change his password and to confirm his new password but then fails to login to the switch. I check the ACS and it says his account is expired. I am using transport input ssh on the vty lines I'm not sure if this is the issue?
Please Help!!!
Correct Answer by Jagdeep Gambhir about 9 years 1 day ago
Yes, it does
Correct Answer by Jagdeep Gambhir about 9 years 2 days ago
SSH password aging, one-time password change etc are supported by bug CSCin91851.
The fix is integrated in version 12.4(10.01)T.
Do rate helpful posts
Overall Rating: 5 (2 ratings)
ps3696 Tue, 10/23/2007 - 07:52
Does this bug affect other IOS versions? I am running 12.1 and 12.2 Thanks
