hallo i must change my system name of the wlc 4402 i want to do it by cli but i dont know how? it is important beacause now its a two word name and it must be one word otherwise my aaa doesnt work.
If the system name is mistyped while you configure the WLC using the CLI wizard, you can change it later with the config sysname command. You do not have to re-do the CLI wizard in order to correct the system name.
Dennis
