IPSEC Tunnel not being created....
Oct 23rd, 2007
We are adding a new tunnel to an existing PIX (B) that already has other connections up and running. Interesting traffic being sent from inside "B" to "A" does not initiate conenction. Tunnel config's attached... Any suggestions will be warmly regarded. Thanks.
sorghum_gao Thu, 10/25/2007 - 09:03
According toyour incomplete configuration, I can only give some advices:
1.isakmp identity address
the default isakmp identity is hostname
2.In pix B, you use the feature "pfs", but not in pix A.
3.Do you allow the vpn traffic to reach the firewall? I can not see the config
sysopt connection permit-ipsec
