Configuring a DMVPN with DSL for Backup.
Oct 23rd, 2007
We currently have 2 locations one in the US and one in the UK, and these are connected to a point to point T1/E1 and running fine. We want to add a backup to this just in case of an outage. We went with a cable connection in the US and a DSL in the UK. I have the cable connection going to an Ethernet port on in the US and a WIC-1ADSL installed in the router in the UK. By the way both routers are 2811's. We have a static IP in the UK and for some reason they can't give us a Default Gateway and we have a static IP here in the US as well. All that being said I can't get the tunnel to come up. Here is the code I entered in the UK for the DSL.
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 8/48
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
keepalive 5
down-when-looped
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password blah
dialer-list 1 protocol ip permit
Anyway any would be appreciated.
D
mbroberson1 Tue, 10/23/2007 - 11:11
If you want to configure DMVPN using DSL as a backup it works great! We are doing it running EIGRP. What protocol are you running over your WAN?
ddevecka Tue, 10/23/2007 - 11:22
We are EIGRP.
Can you give a rough idea of the config because I am getting nowhere.
