RME 4.05: Device Credential Verification Settings mismatch Device Center
Oct 23rd, 2007
Hi folks!
I configured the "RME -> Admin -> Device Mgmt -> Device Credential Verification Settings", to check only the following credential:
Read Community, Read Write Community, Telnet, Enable by Telnet
After this, I open the "Device Center", I chosed a device and I performed the Management Tasks "Check Device Credential".
It create a Device Credential Verification job, for all credential available, like shown below:
Work Order
Name: Device Credential Verification Job Work Order
Summary: General Info
Job Id: 1284
Owner: hpadmin
Description: CDA job from Device Center.
Schedule Type: Immediate
Creation Time: 23 Oct 2007 15:58:57
Start Time: 23 Oct 2007 15:58:57
Credentials Selected: Read Community, Read Write Community, SNMPv3, Telnet, SSH, Enable by Telnet, Enable by SSH
Devices Selected: C-2501-ALES-ASDA-1.
End Time: -
Is it correct that the Device Center verification task, respect the "Device Credential Verification" settings in RME configuration?
Thanks a lot!
yjdabear Tue, 10/23/2007 - 07:03
Seems to me it should be the other way around: RME respects the setttings in DCR.
Joe Clarke Tue, 10/23/2007 - 07:28
Settings are not respected. All credentials are verified when you select the task from the Device Center. This is fixed in LMS 3.0 kind of. In LMS 3.0, once you click on the Check Device Credentials task, you get another screen which lets you pick the credentials you want to check. Sadly, the admin settings in RME are still not respected.
