Cannot Access ASDM
Oct 23rd, 2007
We have a new ASA 5505. We could get into the ASDM as long as we used the defaults; however, we have now got the box working using Vlan1, inside, security level 100, address 192.168.0.2 255.255.255.0 because our inside network is 192.168.0.1...192.168.0.255.
We have Vlan2, outside, security level 0,address 209.174.96.150 255.255.255.0. with switchport access vlan2
How do we change the default http 192.168.1.0 255.255.255.0 inside to be happy with our network so we can use ASDM? Thanks very much for any suggestions. We are, of course, new to Cisco command line language.
Leon Mosier
Technology Director
Mendota High School
2300 West Main
Mendota, IL 61342
815 539 7446 x531
[email protected]
JORGE RODRIGUEZ Tue, 10/23/2007 - 08:00
  • Green, 3000 points or more
Hi, if your inside subnet is 192.168.0.2 you can do it in couple of ways.
allow any subnet host on the inside or specific subnet
e.g
first remove the old http as
no http 192.168.1.0 255.255.255.0 inside
no telnet 192.168.1.0 255.255.255.0 inside
then add new
http 192.168.0.0 255.255.255.0 inside
telnet 192.168.0.0 255.255.255.0 inside
or like this for any subnet inside
http 0.0.0.0 0.0.0.0 inside
telnet 0.0.0.0 0.0.0.0 inside
[edit] or permit admin by specific host,
http 192.168.0.x 255.255.255.255 inside
telnet 192.168.0.x 255.255.255.255 inside
where x is actual host IP.
lmosier Tue, 10/23/2007 - 08:37
Thanks! We will give it a try later today.
lmosier Tue, 10/23/2007 - 12:45
Yippee! It worked! Thanks for your valuable help.
Leon
JORGE RODRIGUEZ Tue, 10/23/2007 - 13:48
Glad is all set , also as a rule every change on devices save the configuration with " write mem "
please rate all helpful post.
Rgds
Jorge
