full bgp routing table
I'm having an issue receiving a full routing table if my primaire route goes down.
network:
ISP1-------r1-----
r3
ISP2-------r2-----
r1 and r2 are connected to the isp's via BGP
r1 and r2 are connected to r3 via ibgp
r3 receives 200k routes and 70% off these routes go to isp1
If I now disable the neighbor session to r1. R3 does not update his routing table to use the routes to isp2 and has only 50k routes.
I'm a bit reluctant posting my router configs here, please let me know which specific info is required to understand and hopefully help me resolve this issue.
Overall Rating: 3 (1 ratings)
gaurav_thapar79 Tue, 10/23/2007 - 07:57
BTW, you muct be learning 200K routes from your eBGP peer not from R3 router.
There is an ambiguity in problem statement.
But as per my understanding your problem , if correct,
please do IGP peer at R3.
Router bgp
Neighbour next-hop-self
neighbour next-hop -self
Try and share your observation, of course rate the post as well.
thx for the reply.
I've got ospf set up as my igp, I thought it wasn't wise to redistribute bgp into ospf. I've got a full mesh ibgp to get all routes to r3.
I can't set up ebgp sessions between r3 and isp's. They only peer with one router.
Next hop self is already configured.
for instance, I thought r3 should have two routes to say www.google.com, and that 1 route gets into the routing table. If that route should fail the backup would automatically be set up in the routing table.
I can see the route to google at r1 and r2, but r3 has only one route that points to r1. If I disable the peering session to r1. R3 does not learn the route via r2.
gaurav_thapar79 Wed, 10/24/2007 - 03:11
Can you use iBGP instead of OSPF to simply the caoncept in terms of implementation and to achieve what you want?
pls revert.
