Multiple Site to Site Tunnels plus Remote Access clients
Oct 23rd, 2007
I have a Cisco 3825 router with security bundle which acts solely as a "VPN router".
There are about 9 static tunnels with peers and pre-share keys defined. I also have 8 or so small Linksys routers which create tunnels to this router. Since these small routers are on cable/DSL we have a wild card policy (no set remote peer). All of the ISAKMP policies are set to no-xauth.
Now my question. Since we have a policy that is set to, basically any remote endpoint (requires pre-share key), I cannot seem to set up a config that allows a Cisco remote access client to connect to this router. Is it possible to get this to work? I have set up SEVERAL RA clients on PIXs and routers, but NOT with the presents of a wild card ISAKMP policy. I'm afraid I painted myself into a major corner. :)
If I do get this to work. My end goal is to implement RAS to authenticate RA clients to active directory.
ANY advice would be appreciated. I have about pulled every hair in my head out.
Respectfully,
Bobby
