MGCP CCM 5.x Router2811 NOT REGESTERING
Answered Question
Oct 23rd, 2007
Overall Rating: 4.7 (3 ratings)
Rob Huffman Tue, 10/23/2007 - 09:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Andre,
It's likely the Domain name issue outlined in this doc (I noticed that your config is set at the default - router);
MGCP Gateway Registration Failure with Cisco CallManager
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805a316c.shtml#prob
Hope this helps!
Rob
jbarcena Tue, 10/23/2007 - 11:46
  • Red, 2250 points or more
Check the Application log in the CCM server, that's how you can see which name is the CCM receiving and just use the exact same name in the GW configuration page.
labredes1 Wed, 10/24/2007 - 00:31
in the CCM i put the ip address of the gateway and not the domain name... Might this be the problem?
I don't know how to see the application log on the CCM...
Andre' Santos
labredes1 Wed, 10/24/2007 - 00:38
Hi again,
that was the problem...I realy had to have the host name instead of the ip address of the gateway,although i thought it be better to use IP.
Thanks a lot all of you
André Santos
