3560 PoE-48 Version 12.2(25)SEB4
Answered Question
Oct 23rd, 2007
I'm trying to find Version 12.2(25)SEB4 on the website, but I cannot find this IOS version. Our other switches have this image and we would like to keep them alike. Can you help me find Version 12.2(25)SEB4?
Correct Answer by fargier about 9 years 4 months ago
switch#dir flash:
see the name of the IOS version
Use tftp server on your computer
switch#copy flash:name_of_IOS_File tftp://x.x.x.x/name_of_IOS_File
where x.x.x.x is the ip of your tftp server
Overall Rating: 5 (1 ratings)
szahid Tue, 10/23/2007 - 09:49
Mike :
That image has been taken off from CCO. If you must have that image , please open a TAC case and have your engineer post it for you.
royalblues Tue, 10/23/2007 - 11:08
If you have this image on other switches, just copy the IOS file from one of the switches and upload.
Alternativley you can setup device itself to act as a TFTP server and upload directly if you have the IP reachability
use the command to make your device a TFTP server
tftp-server flash:
Narayan
Correct Answer
fargier Tue, 10/30/2007 - 02:03
switch#dir flash:
djgizmo250 Tue, 10/30/2007 - 10:38
Is it save to perform this with a production switch? My initial thought is yes, but I just want to make sure. Thanks!
royalblues Tue, 10/30/2007 - 12:19
You should be good to go with this. There should not be any performance impact on the production network due to this.
Narayan
djgizmo250 Tue, 10/30/2007 - 15:19
Entered command:
copy flash:c3560-ipbase-mz.122-25.SEB4 tftp://192.168.241.100/c3560-ipbase-mz.122-25.SEB4
Next line shows:
Address or name of remote host []? 192.168.241.100
Next line shows:
Destination filename [c3560-ipbase-mz.122-25.SEB4]?
After hitting enter, I get:
%Error reading flash:c3560-ipbase-mz.122-25.SEB4 (Is a directory)
What am I doing wrong?
djgizmo250 Tue, 10/30/2007 - 15:34
Where can I find the .tar package?
How can I move the .bin file I just pulled from one our switches to another switch?
