bgp - multiple match command
Oct 23rd, 2007
Can I use a match in a single route-map like this?
route-map prefmyroute permit 5
match as-path 7
match ip address 2
set local-preference 200
ip as-path access-list 7 permit ^200$
access-list 2 permit 10.10.10.0 0.0.0.255
I want to match ip address 10.10.10.0 comming from as 200 and stamp it with local preference of 200. Is this the command to do it?
Overall Rating: 3 (1 ratings)
royalblues Tue, 10/23/2007 - 10:43
  • Green, 3000 points or more
Yes you can do that.
Action will be taken only when it satisfies both the match statements
The above command will try to match the prefix 10.10.10.0/24 and assign a Local pref value of 200 if the AS path only has 200 and nothing else
If you want to match the prefix if the as path includes 200 then the as-path access-list should be something like
ip as-path access-list 7 permit ^200_
Narayan
