AC connector to my Cat WS-C6509-E:L6-20R or L6-30R?
Answered Question
Oct 23rd, 2007
Guys, one more question on this:
if I am planning to buy an UPS to my Cat 6509, which type of connector arrangements should I made? I mean, I know that L6-30R 250V, 30A connectors should be available on the switch itself, but how is that going to change if I get an UPS for this?
Correct Answer by JORGE RODRIGUEZ about 9 years 7 months ago
Hi, the ups female receptacles itself must meet the connector standards for the L6-30 30A plug , make sure the UPS can support this cable plug connector, if that is not feasible and ups itself have regular three connector type female receptacle you could buy a cable adapter in which one end will have the female and other end will have the regular 5-15P male plug to connect to USP. But best is to consult the APC UPS vendor to inquiery the receptacle type on the UPS you will buy, it all depends on the type of UPS, some APC UPSs for example can be ordered with the right female connector type, so best thing is to double check with vendor and let them know the type of cable connector you will be using when connecting switch to UPS.
reference this link connector types section for 6500 series.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00800a7af7.shtml
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Tue, 10/23/2007 - 13:56
  • Green, 3000 points or more
Jorge
