upgrading IOS advise for 3508 switch
Oct 23rd, 2007
Have not done an ios upgrade for this switch in a while (AS YOU CAN See)...It is currently at the following IOS version:
Version 12.0(5)WC3b
Please let me know what IOS version I should upgrade this switch.
I also have a 2950G 48 ports, with ios version 12.1(13)EA1.
I need some advise what to upgrade and what ios to avoid??
thanks
royalblues Tue, 10/23/2007 - 12:01
  • Green, 3000 points or more
For the 3508, the latest one available is
120-5.WC17 and for the 2950 it is 121-22.EA10a
BTW, is there any particular reason you want to upgrade your devices like a new feature support etc.
Narayan
royalblues Wed, 10/24/2007 - 08:20
The NEw IOS would definitely have resolution to some known bugs and hence is recommended provided you have sufficient flash and memory.
Better to backup your current IOS just in case you need to revert them. Some old IOS may not be available in CCO now
Narayan
