Outbound call
Rob Huffman Tue, 10/23/2007 - 12:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Daniel,
Here is an example that shows tracing 911 calls. You should be able to replace 911 with the Called Number you are looking for and be good to go;
Using SQL Queries to Search the Call Detail Record with Cisco CallManager
Search for Calls Made to a Specific Number
In some situations, you might need to find out the extension which called 911 on a specific date. Complete these steps in order to search for calls made to a specific number such as 911.
In order to search for calls that are made to a specific number, you can run a different query.
For example, if you want to look for calls to 911 you can enter the query select * from CallDetailRecord where finalcalledpartynumber='911'.
The bottom of the page displays all the entries in the CDR that have the final called party number equal to 911.
Add a date to this query in order to refine it.
For example, for all calls to 911 after August 1st, 2003, run the query select * from CallDetailRecord where finalcalledpartynumber='911' and datetimeconnect > '1059696000'.
The bottom of the page displays all the entries in the CDR that have the final called party number equal to 911 made after August 1st, 2003. '1059696000' is the universal time in seconds for August 1st, 2003.
In order to see who calls 911, run the query select callingpartynumber from CallDetailRecord where finalcalledpartynumber='911'.
From this doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d71c5.shtml
Hope this helps!
Rob
