Unity 4.x design/implementation question
Oct 23rd, 2007
Can one Unity system support two different Exchange systems? I think it can but need confirmation.
Any thoughts appreciated.
Maddox
jbarcena Tue, 10/23/2007 - 13:45
  • Red, 2250 points or more
Yes you can, you can only point Unity to one Exchange server with the Message Store Configuration Wizard, but as long as both Exchange are able to see each other then Unity can see both, when you run Permissions Wizard you should see the mailstores for both Exchange servers.
//Jorge
