Swap active and hot 6500 720 sup's without reloading
Oct 23rd, 2007
Last weekend I upgraded 720 sup's in and when done, wanted to swap the active and hot blades (were in SSO mode). I did the "redundancy force-switchover" command which works fine but it reloads the previous active sup. Is there a better way to do this without reloading? Seems unnecessary when all I want to do is change their states.
nambi_gct Thu, 10/25/2007 - 02:49
It is normal.Generally hot standby supervisor takes over the active role, only when the current active goes down.Hence when you do "redundancy force switch-over" the current active supervisor reloads.Also this should not impact the system operation.I dont think you can avoid this reload.
Nambi.
