851w and Steam
Oct 23rd, 2007
Having problems retrieving server list on Steam for Team Fortress 2. The ports that need opening are:
* UDP 27000 to 27020 inclusive
* TCP 27020 to 27050 inclusive
I've added those to my access-list 102, but still can't retrieve the server list. Not sure what I am missing.
amritpatek Mon, 10/29/2007 - 15:37
  • Silver, 250 points or more
Make sure that IPS services are not enabled on your router because of the way the packets are handled by Team Fortress the IPS may get the impression of a DoS attack and may block the packets. Check the router logs if it is discarding the packets.
cigar3tte Mon, 10/29/2007 - 23:11
Says I do not even have an IOS image that supports IPS.
kalle-moller Wed, 03/26/2008 - 03:46
Well you have allowed
access-list 102 permit udp any any eq 27020
If the ports is what you say it should be
access-list 102 permit udp any any range 27000 27020
AFAIK
