ASA behind Checkpoint FW
Oct 23rd, 2007
Does anyone know if there's any known issues regarding using an ASA to connect directly to a Checkpoint Firewall. I'm trying to set up a test network from a 6509 connecting to an ASA, then directly to a Nokia Checkpoint, then to the outside.
The ASA appears to be blocking TCP connections even though all interface ACLs are set to allow all...
Fernando_Meza Tue, 10/23/2007 - 20:03
  • Gold, 750 points or more
Please be aware that you also need to allow access by configuring static nat..
static (inside,outside) X.X.X.X Y.Y.Y.Y netmask C.C.C.C
where X is the IP address as it appears outside of the Firewall
y is the IP address as it appears inside the firewall
mask identifies whether is is a host or a range of addresses ..ie. a full segment
I hope it helps .. please rate it if it does !!!
