Frame Relay Question
Oct 23rd, 2007
Hi Pro's!
Just want to ask if the upload/download of frame relay connection is thesame? if i have 64kbps connection, what is my upload and download speed?
tnx in advence!
paolo bevilacqua Tue, 10/23/2007 - 17:17
  • Hall of Fame,
    Founding Member
In frame relay there is more than one speed. First one is access speed, that is your circuit speed and is generally the same in both directions, except for satellite links and special cases.
Then you have CIR that is kind of a service guarantee for a max rate you can send and will be delivered, that would be a conservative speed for upstream, because is less (but may be equal) to access speed.
The other direction can also have same or different CIR.
