CCNA question about boot files
Oct 23rd, 2007
As a Certkiller.com instructor you are required to place the following items to the correct order they are used when Cisco IOS based hardware is booted.
Flash, NVRAM, TFTP, ROM.
What should be the correct order? Thanks.
srue Wed, 10/24/2007 - 09:35
  • Blue, 1500 points or more
1 ROM contains the bootstrap image
2 FLASH contains the standard IOS image
2a. TFTP (optional) contains ios image
3 NVRAM contains the startup config
xs_echoss Wed, 10/24/2007 - 09:46
Yea, this is what i think. but according to the answer explanation i got, the question is asking about the order to locate an usable IOS file. Then it should be: flash, tftp, ROM. but i am not sure about NVRAM, cuz it is usually too small to store an IOS. maybe the answer is wrong.
mazchile83 Tue, 10/30/2007 - 10:12
I believe the NVRAM only holds the
startup-config
The IOS should load as you mentioned, Flash, TFTP, ROM.
I am new to this so I could be mistaken.
NateBattle Tue, 10/30/2007 - 10:38
Default boot sequence for Cisco IOS software:
1. NVRAM
2. Flash (sequential)
3. TFTP server (network boot)
4. ROM (partial IOS)
xs_echoss Tue, 10/30/2007 - 10:46
How could a NVRAM holds an IOS? It is usually only 32K, but an IOS needs at least few megabytes.
