3750G-12S Port Grouping
Answered Question
Oct 23rd, 2007
Does anyone know off-hand how the ports are grouped together on the backplane/motherboard? I'm wondering as I have a switch that the first 2 ports of each 4-plex (1&2, 5&6, 9&10) are giving crc errors, input errors, and flapping for no reason we can determine. Seems odd that other 6 ports are operating normally.
Correct Answer by andrew.burns about 9 years 7 months ago
I think it's 4 ports per asic, but you can use the following command to check:
show platform pm if-numbers
The port column shows the asic that the port is attached to.
Andrew.
Overall Rating: 5 (1 ratings)
Correct Answer
andrew.burns Wed, 10/24/2007 - 00:13
  • Gold, 750 points or more
Andrew.
