Having problem in adding a device to inventory
I have 295 devices added to LMS inventory (to prove the there is nothing wrong with the setup/deployment).
Now that i am trying to add a device (
My NMS is placed at Site B...Here is the arch
Test_Swicth -> Access_switch_Site_A --> Core_Switch_Site_A --> Router_Site_A --> Router_Site_B --> Core_Switch_B --> Access_Switch_Site_B --> NMS_Server
I have full connectivity, and i am getting the ping response to & from NMS_Server to & from Test_Swicth.But when i try to add this device, NMS puts this in NOT RESPONDING list of devices, saying that "Could not connect to host:"
I am still able to add other devices...
Here is the output of what i get from "Management Station to Device"..
UDP failed
sent: 5 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 64 protocol: udp port: 7
TCP failed
sent: 0 recvd: 0 min: 0 max: 0 avg: 0 timeout: 0 size: 0 protocol: udp port: 7
HTTP okay
sent: 5 recvd: 5 min: 0 max: 0 avg: 0 timeout: 2 size: 33 protocol: http port: 80
TFTP failed
sent: 5 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 25 protocol: tftp port: 69
TELNET okay
SNMPR failed
sent: 5 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 91 protocol: snmp_get port: 161
SNMPW failed
sent: 0 recvd: 0 min: 0 max: 0 avg: 0 timeout: 2 size: 0 protocol: snmp_set port: 161
SSH failed
I am using RME 3.5
miheg Wed, 10/24/2007 - 05:03
  • Gold, 750 points or more
So you can ping this host but can you ping the host from the console of the ciscoworks server?
You can get to the device with icmp ping, http and telnet but not with snmp.
Recheck the community strings and access-list on this device and in the DCR of ciscoworks.
you could enable debug snmp packets on the device to see if the packets from ciscoworks get to the device.
Cheers,
Michel
