QoS over frame relay
Answered Question
Oct 24th, 2007
I am managing a medium to large frame-relay network consisting of mainly 64k lines to the remote nodes. I am using policy-maps, linked to class maps , linked to ACL's on the sub-interfafces, however I notice my predecessor have also attached ACL's both inbound and outbound for similar traffic on the main interfaces. Question ??? will the ACL's on the main interfaces override the policy map on the sub-interface?? please advise soonest....
Correct Answer by royalblues about 9 years 4 months ago
Not really...
The ACLs on the interface are really meant for allwoing a certain type of traffic while the QoS ACLS are referencing them to give treatment as per your defined policy
Narayan
Overall Rating: 3 (1 ratings)
royalblues Wed, 10/24/2007 - 00:47
The IP ACLs will be applicable on the interface carrying the IP addresses which should be subinterfaces in your case
Narayan
bradley.johnson Wed, 10/24/2007 - 00:56
Thanks for that, but how come I still get matches on the ACL at the main interface?
bradley.johnson Wed, 10/24/2007 - 01:10
Oops. the ACL's actually are both on the sub-interface, anyway have a look at the snapshot and tell please tell me if I remove the ACL's .
interface Serial2/3:30
description WCape Corp SomersetMall-51-02849-00
bandwidth 64
no ip address
encapsulation frame-relay
ip route-cache flow
load-interval 30
no arp frame-relay
frame-relay lmi-type ansi
frame-relay intf-type dce
end
Wcape_Kenil2#sh run int s2/3:30.1
Building configuration...
Current configuration : 266 bytes
interface Serial2/3:30.1 point-to-point
bandwidth 64
ip address 171.131.1.51 255.255.0.0
ip access-group pnp_all in
ip access-group pnp_all out
ip nbar protocol-discovery
no arp frame-relay
frame-relay class storesap
frame-relay interface-dlci 900
end
Wcape_Kenil2#sh poli
Wcape_Kenil2#sh policy-map storesap
Policy Map storesap
Class q1
Bandwidth 8 (kbps) Max Threshold 64 (packets)
Class q2
Class sap_qos
Bandwidth 30 (kbps) Max Threshold 512 (packets)
Class q3
Bandwidth 8 (kbps) Max Threshold 512 (packets)
Class q4
Class class-default
Flow based Fair Queueing
Bandwidth 0 (kbps)
exponential weight 9
class min-threshold max-threshold mark-probablity
0 - - 1/10
1 - - 1/10
2 - - 1/10
3 - - 1/10
4 - - 1/10
5 - - 1/10
6 - - 1/10
7 - - 1/10
rsvp - - 1/10
royalblues Wed, 10/24/2007 - 01:17
If you are referring to the access-list pnp_all then it is not being used for the QoS but mostly being used to restrict traffic flow in and out of the interface.
If you remove the access-group statements, any traffic to the interface will not be matched against the access-list.
I think mostly the access-list is allowing only certain traffic to be sent or received on the interface
Narayan
bradley.johnson Wed, 10/24/2007 - 01:28
Thanks, 1 last question:
1. the acl called pnp_all consist of 211 lines, most of the permits also live in the Qos ACL's ( Q1,Q2 etc),
My netflow graphs dont reflect the true construct of my QoS policy, could the cause be the ACL called pnp_all????
Correct Answer
royalblues Wed, 10/24/2007 - 01:35
Not really...
Narayan
