ASDM lost connection tto the Firewall
Oct 24th, 2007
I lose the connection to ASDM after 5 sec.
I became this Error when i do 'wr mem':
ASDM received an error while sending this command. Click Resend and if the browser
prompt you to verify a new certificate or to provide a username/password, please do so.
I must restart the ASDM.
best regards,
Marie
pjhenriqs Wed, 10/24/2007 - 02:50
Check the Java version you have. I had the same problem because I was using Java 6, so I downgraded to Java 5 and everything started working again.
Sometimes it's best not to upgrade :)
marie-pongou Wed, 10/24/2007 - 02:58
I have a old Version of java. I don't think that
this is a Java-Problem, because i use the same ASDM Version for another Firewall and I dont have any problems whit this.
best regards
M.
pjhenriqs Wed, 10/24/2007 - 03:03
Ok.
Are you running ASDM as an applet or do you have it installed on your PC?
Which version?
marie-pongou Wed, 10/24/2007 - 03:17
I am running ASDM from my PC, version 5.2(2).
I became the same error when i am running ASDM as an applet.
pjhenriqs Wed, 10/24/2007 - 03:45
To be honest I have the same version and I have never had that problem so I really don't know. If I were you I would try upgrading/downgrading the PIX/ASA image and the ASDM and verify if the error persists.
Also, I would suggest you open a TAC case with Cisco. This is not a normal behaviour.
Sorry I couldn't be of more help.
mathias.mahnke Sun, 01/06/2008 - 08:30
Since upgrading to a new notebook / latest java environment this error occurs with all 5.x asdm sessions. This looks like an asdm - jre problem and is still unsolved?
marie-pongou Mon, 01/07/2008 - 03:20
The Problem is solved after a new Installation for ASDM 5.x. Update or upgrade for jre was not necessary. I don't know was happend.
best regards
Marie
mathias.mahnke Mon, 01/07/2008 - 06:12
Marie,
interessting... I do suffer from this error on different (windows) pcs. This also happend with a brand-new notebook. So my guess is, that this wouldn't be the solution in any case.
Thanks for your feedback.
Mathias
