10-24-2007 12:50 AM
CSS# show summary
Global Bypass Counters:
No Rule Bypass Count: 3606
Acl Bypass Count: 0
Owner Content Rules State Services Service Hits
IFAP Tst.Ifap.Local Active esl0008 141542
esl0019 138403
Tst.Man.Ifap.Loc Active esl0008 0
esl0019 0
Tst.Sec.Ifap.Loc Active esl0008 5
esl0019 6
Tst.Aplj.Ifap.Lo Active esl0008 15
esl0019 15
SSL-Tst.Sec.Ifap Active MODSSL 9
SSL-Tst.Aplj.Ifa Active MODSSL 26
SSL-Tst.Login.If Active MODSSL 23739
Any one knows how to clear this summary stats?
I've tried w/ no results:
- clear statistics
- zero ip statistics
Best Regards,
Petrónio
Solved! Go to Solution.
10-24-2007 01:02 AM
If i recall correct...
conf t
owner IFAP
zero all
... will do the trick. I am not sure though if you have to do it per content-rule or if it is sufficient to issue per owner.
My CSS's are switched off so i can't test it anymore. :)
Roble
10-24-2007 01:02 AM
conf t
owner IFAP
zero all
Roble
10-24-2007 01:41 AM
Thank you very much !
Bruno Petrónio
