Spannig Tree Portfast
Answered Question
Oct 24th, 2007
Hi All
Should I configure on the interfaces
spanning-tree portfast to hubs and switches when these are connected to our main switch?
Correct Answer by ankbhasi about 9 years 4 months ago
Hi Friend,
Actually yes anything which can give an access and connection to multiple connections/nodes and then loop back to the same switch is a risk.
Ankur
*Pls rate all helpfull post
Correct Answer by glen.grant about 9 years 4 months ago
No you never enable portfast on links attached to other network devices , this is only used on client access ports. Network device links should have portfast turned "off".
Overall Rating: 5 (2 ratings)
Correct Answer
glen.grant Wed, 10/24/2007 - 01:08
qwertys21 Wed, 10/24/2007 - 01:40
Thanks Guys
Even if these hubs and switches are not intelligent and they are passive hubs and switches?.
Correct Answer
ankbhasi Wed, 10/24/2007 - 01:46
Hi Friend,
Ankur
Francois Tallet Wed, 10/24/2007 - 07:20
I agree with all of the above. As usual, those are high level rules to avoid shooting yourself in the foot. The most important point is that there must be no loop introduced by the L2 device to which you're connecting your portfast port. In fact, I would not hesitate using portfast to a hub where only end stations are connected;-) (doing so to a switch would be much more controversial but potentially not impossible either).
Francois
