Webview not showing historical reports
Oct 24th, 2007
I have an IPCC Enterprise 7.2 and webview historical reports are not working.
Real time reports are working ok.
I have tried similar cases in tech tips and in forums with not success.
Although I have opened a case, could anyone help me?
Thanks in advance
Raul
Overall Rating: 5 (1 ratings)
Riccardo Bua Wed, 10/24/2007 - 03:20
  • Cisco Employee,
Hi Raul,
I had a template with at least 8 scenarios for it, you are truly better off working in the Service Request on this ;-)
Riccardo
This is date time format issue for Sybase ODBC config file, just do a search inside file 'pbodb100.ini' for "datetime format" field, correct datetime format to 'mm-dd-yyyy', and restart "jaguar service".
This issue used to happening for French Webview in 7.1, now it is fixed in 7.2 for French one, but goes to English.
Wei
castrillor Wed, 10/24/2007 - 08:41
Hi wei,
Thanks for your help. It worked.
YOu have got a 5 rate :).
Iam facing the same problem, I did change the ini file as suggested, still having the problem.
The chages i did is as below
; Date Formats
[DEFAULT_DATETIME]
PBDateFmt=''{d '\'mm-dd-yyyy\'' }''
PBTimeFmt=''{t '\'hh:mm:ss\''}''
PBDateTimeFmt=''{ts '\'mm-dd-yyyy hh:mm:ss.ffffff\''}''
[ISO_DATETIME]
PBDateFmt='\'yyyy-mm-dd\''
PBTimeFmt='\'hh.mm.ss\''
PBDateTimeFmt='\'mm-dd-yyyy-hh.mm.ss.ffffff\''
[STANDARD_DATETIME]
PBDateFmt='\'mm-dd-yyyy\''
PBTimeFmt='\'hh:mm:ss\''
PBDateTimeFmt='\'mm-dd-yyyy hh:mm:ss.ffffff\''
[MSSQLSERVER_DATETIME]
PBDateTimeFmt='\'mm-dd-yyyy hh:mm:ss.fff\''
[NO_MSECS_DATETIME]
PBDateTimeFmt=''{ts '\'mm-dd-yyyy hh:mm:ss\''}''
Reg/OS
