Templates for webview
Oct 24th, 2007
Hi List;
Any one has idea about the method for using a templates with webview, so we can import a kind of templates to be used with webview reports? Any direction?
Bilal
antonio.vazquez Wed, 10/24/2007 - 01:56
  • Bronze, 100 points or more
to manipulate webview reports, you can use Sybase Infomaker 10 (only works with this version). With Infomaker you need to open files with extension pbl that are the files that contains report definition. You can find that files at the following address :\icm\\aw\custom. In this folder there are several subfolder like AgTeam,AgPer tha contains that pbl files.
You can find more information at
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps4145/products_user_guide_list.html
Best regards.
Antonio
bilalghayad Wed, 10/24/2007 - 02:56
Thanks a lot Antonio.
Infomaker is free or licensed? If free, from where I can download it.
Bilal
lpezj Wed, 10/24/2007 - 03:00
  • Gold, 750 points or more
Infomaker is licensed. You can purchase it from Sybase.
Hope this helps,
Juan Luis
