LISENCE PROBLEM
Oct 24th, 2007
in order to do lisencing the publiser server we need to upload two lisence (publisher,subscriber server )my question is which MAC ADDRESS we have to give for lisencing the publisher server wheather of publisher or subscriber server(MAC ADDRESS)
Rob Huffman Wed, 10/24/2007 - 04:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Subhasis,
This will be the MAC of the Publisher server. The Publisher will become the License Manager. Here is a clip;
Uploading a License file
Use the following procedure to upload a license file to the Cisco CallManager server with the matching MAC address (Publisher) that is provided when requesting for a license file. The Cisco CallManager server where the license file is loaded takes on the functionality of the "license manager".
Note Upload the license file only on the first node of Cisco CallManager cluster.
Procedure
Step 1 Choose System > License > Upload License File.
The License File Upload window displays.
Step 2 The Existing License Files drop-down list box displays the license files that are already uploaded to the server.
Note Click View File to view the file content of any existing files.
Step 3 To choose a new license file to upload, click Upload License File.
The Upload File pop-up window displays.
Step 4 Browse and choose a license file to upload to the server.
Step 5 Click Upload License File.
After the upload process is complete, the Upload Result file displays.
Step 6 Click Close.
Step 7 In the License File Upload window, the status of the uploaded file displays.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080530f9b.html#wp1049590
Hope this helps!
Rob
jay_bharti Wed, 10/24/2007 - 04:35
dear ROB HUFFMAN
i do this but i also put my subscriber license and then shown status is both are Publisher.
so plz give solution what's Problem
wboonshen Tue, 10/30/2007 - 18:49
I have this problem as well where both my cm status shows that they are publisher when i remember clearly during the installation i have defined one of them as a subscriber. Any ideas?
Tommer Catlin Wed, 10/31/2007 - 08:58
  • Green, 3000 points or more
When you installed the publisher, did you fully install it as "first Node" in the cluster. Once online, you need to add the licensing into the Publisher based upon the MAC address of Pub.
Once it is up and running, THEN you can install the subscriber. Don't install the subscriber until you have all the licensing completed on the Publisher.
Licensing lately at Cisco has been iffy. You need to verify what licenses you have in your contract and also on the PAK. It's not as easy as it used to be. You sometimes have to register about 3 PAKs just to get CM5/6 up and running. There are different types of .LIC for CCM. Application, Nodes, DLUs, etc.
When you email Licensing, have them verify what the license is for.
#of Nodes
#of DLUs
Application services?
And when you do install your Subscriber, it should be asking you to join the cluster. Everything must be up and running on the publisher or the Subscriber will not even get through install. (or will, but not licensed for the Node.)
