Recover router
Oct 24th, 2007
Dear All,
While doing a password recovery on 2691 router, i accidentally changed the config register value to 0x2162 instead of 0x2142. Now i get all junk while booting the router.
Is there a way where i can undo this mistake?
Thanks a lot
Gautam
smothuku Wed, 10/24/2007 - 04:36
Hi Gautham ,
Chnage the baud rate starting from Min. value to Max.value and check whether you are getting rommon mode at one particular value.
satish
